JATINDPCS
Jul 05, 2018Aspirant
WNDAP360 RMA / Replacement
Our AP is faulty and Unable to Browse the AP, Power LED continuously blinking Amber and cannot find the SSID broadcasted by AP. Reset several times but no effect. result is same. Also Status & LAN LE...
- Feb 04, 2019
Hi JATINDPCS,
I checked the progress of your case # 40041995 and I got an information that you have already received your refund on your bank account. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Feb 04, 2019NETGEAR Employee Retired
Hi JATINDPCS,
DaneA
JATINDPCS
Feb 04, 2019Aspirant
Accepted Solution
