krja1012
Dec 26, 2017Aspirant
WNDAP620 as repeater for Fritzbox wireless signal
Hello, I bought me the WNDAP620 AccessPoint as WLAN Repeater. I'm using a FritzBox 7490 which is connected to the internet. Now I want the WNDAP to repeat the Wireless signal from the Fritzbox t...
- Dec 27, 2017
Hi krja1012,
Welcome to our community!
Unfortunately, we cannot use the WNDAP620 as a repeater for your fritzbox. WNDAP620 supports wireless bridging but it should only be connected to another NETGEAR access point.
If you wanted to use a repeater, you might want to check our WiFi range extenders.
JohnC_V
Dec 27, 2017NETGEAR Employee Retired
Hi krja1012,
- krja1012Dec 28, 2017Aspirant
Hi JohnCarloV,
thanks for your answer :) In this document I found that the WNDAP620 has a "Repeater Mode", so I thought that it can repeat WLAN signals.
http://www.downloads.netgear.com/files/GDC/datasheet/en/WNDAP620.pdfAdvanced Wireless Features Wireless Distribution System (WDS) • Bridge mode: Point-to-point wireless WDS mode • Bridge mode: Point-to-multipoint wireless WDS mode • Repeater mode • Adjustable Transmit Power Control (TPC) from 100 mW down to 0 mW
Now I'm confused a little bit.
Despite of that, which access point base stations I can use here? (no problem to connect the base station to LAN cable)
RegardsJan
- JohnC_VDec 28, 2017NETGEAR Employee Retired
krja1012,
Yes, you are correct. But it can only be used as a repeater of another NETGEAR access point as per the image attached above. As long as it is a NETGEAR Business Access Point that supports wireless bridging.
- JohnC_VJan 01, 2018NETGEAR Employee Retired
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
- krja1012Jan 01, 2018Aspirant
Hi,
I bought another WNDAP620. I will connect this one directly to fritz box by wire and then I'll try to get the bridge to the other WNDAP620 running.
I hope this will work like expected.
Thanks for your answers :)
Regards
Jan
