esaym
Dec 22, 2016Aspirant
WNDAP660 Connectivity Issues
I'll try to keep this story as short as possible. I run a small office and about two years ago I upgraded an older netgear G only access point to a newer WN203. All was well for about a year. Then I...
- Apr 20, 2017
So since the firmware upgrade and a factory reset this has been working.
DavidTunstall
Jan 24, 2017Aspirant
Within 24 hours of re-enabling AMPDU both of my WAPs have locked up even with WMM Powersave disabled. I have now reverted to my stable configuration of AMPDU disabled on both 2.4Ghz and 5GHz. Since disabling AMPDU no further locks have occured and both WAPs are now stable.
Regards
David
zappullae
Feb 20, 2017Aspirant
When the WAP goes south can you reach any web site by IP instead of DNS name?
- DavidTunstallFeb 20, 2017Aspirant
For me the whole band locks up. I cannot access any local or remote devices via the WAP. I can however access the WAP via ethernet or the other band that has not locked up which is basically functioning normally.
I've now been operating for weeks without issue purely by disabling AMPDU. As you say not ideal but at least trouble free.
Regards
David
- DurgaMar 03, 2017NETGEAR Expert
We have a fix for this issue in the recent firmware that hasn't been released to the wider community yet. We appreciate you testing this firmware and let us know if your wireless issue fixed. Our support moderators will be in touch with you and release the firmware. The public availability of this release will be in April, until which time you should use the private image from our support team.
- zappullaeMar 03, 2017Aspirant
I have installed the new firmware. Can we get an idea of what was changed?
- DurgaMar 06, 2017NETGEAR Expert
Hi Zappullae,
We are hitting a corner case where the packets are stuck in the firmware. This will happen with some smart phones (especially recent ones) and specific applications running on them coupled with bad RF environment and high channel utilization. We made minor changes in the software to handle this particular condition.
Has the new firmware fixed your problem?
Thanks,
Durga.
- zappullaeMar 06, 2017Aspirant
It takes a time to know if it works. So far so good. We'll know in about 2 weeks to a month.
- zappullaeMar 12, 2017Aspirant
So far it hasn't hung up but its unsuablly slow. The propgress bar on FireFox (Samsung tablet) get to the place where it used to hang and pauses. Then 75% of the way and pauses. An Amozon product page takes forever to open. Unusable.
Well now it looks like I spoke too soon. The WAP had been slowing down and now its hung up. I'm done with this POS.
- RaghuHRMar 12, 2017NETGEAR Expert
Are you seeing the same exact propblem what you used to see earlier? Is it possble to have remote session with your setup to understand more of your case?
Thanks
Raghu
- zappullaeMar 13, 2017Aspirant
Similar, Its slower all the time. Before the patch it was faster until it hung up now its slower and takes longer to hang. One thing I can saw is as I have reported here in the past I bought this "high end" WAP because my NETGEAR WNDR3700 huing up and I had to keep rebooting it the same way the 660 does. I appretiate your offer of help bit its not possible to do a remote session because I've been messing with this for over a year and I'm done with it. Time to buy a WAP that works.
And it just hung up again. The fix made it worse. I took it down. Terrible device.
- zappullaeApr 20, 2017Aspirant
