esaym
Dec 22, 2016Aspirant
WNDAP660 Connectivity Issues
I'll try to keep this story as short as possible. I run a small office and about two years ago I upgraded an older netgear G only access point to a newer WN203. All was well for about a year. Then I...
- Apr 20, 2017
So since the firmware upgrade and a factory reset this has been working.
zappullae
Mar 12, 2017Aspirant
So far it hasn't hung up but its unsuablly slow. The propgress bar on FireFox (Samsung tablet) get to the place where it used to hang and pauses. Then 75% of the way and pauses. An Amozon product page takes forever to open. Unusable.
zappullae
Well now it looks like I spoke too soon. The WAP had been slowing down and now its hung up. I'm done with this POS.
- RaghuHRMar 12, 2017NETGEAR Expert
Are you seeing the same exact propblem what you used to see earlier? Is it possble to have remote session with your setup to understand more of your case?
Thanks
Raghu
- zappullaeMar 13, 2017Aspirant
Similar, Its slower all the time. Before the patch it was faster until it hung up now its slower and takes longer to hang. One thing I can saw is as I have reported here in the past I bought this "high end" WAP because my NETGEAR WNDR3700 huing up and I had to keep rebooting it the same way the 660 does. I appretiate your offer of help bit its not possible to do a remote session because I've been messing with this for over a year and I'm done with it. Time to buy a WAP that works.
And it just hung up again. The fix made it worse. I took it down. Terrible device.
- zappullaeApr 20, 2017Aspirant
