zappullae
Dec 20, 2016Aspirant
WNDAP660 Internet Access Keeps Loosing Access
My WAP keeps loosing access to the internet and it does it quite often; 6 times an hour, all my wireless devices loose Interment access. They all have WIFI connectivity to the WAP and maintain their...
- Mar 03, 2017
Dear All
We have made potential fix for this kind of issue. Could you please reach us https://www.netgear.com/support/contact.aspx to get the patch image?
Thanks
Raghu
zappullae
Dec 21, 2016Aspirant
Thank you I will contact them. I'm trying one thing right now. I set the 5G chanell to auto. It was at at chanell 11. I will let u know in a few days.
JohnRo
Dec 21, 2016NETGEAR Employee Retired
Hi zappullae,
That was one of the suggested steps on your previous contact with support. We'll wait for your feedback.
Thanks,
- zappullaeDec 22, 2016Aspirant
Unfortunately that didn't fix it. So last night it was fine and fast. The first connection this morning failed again. I had to disable and reenable WIFI on the device.
- JohnRoDec 22, 2016NETGEAR Employee Retired
Hi zappullae,
I looked up your record and it appears that the RMA is now in place.Let us know once you received the replacement unit.
Thanks,
- zappullaeDec 23, 2016Aspirant
So the replacement arrived and is up and running. I took all the defaults except for the SID and PSK. We'll see how this works.
