zappullae
Dec 20, 2016Aspirant
WNDAP660 Internet Access Keeps Loosing Access
My WAP keeps loosing access to the internet and it does it quite often; 6 times an hour, all my wireless devices loose Interment access. They all have WIFI connectivity to the WAP and maintain their...
- Mar 03, 2017
Dear All
We have made potential fix for this kind of issue. Could you please reach us https://www.netgear.com/support/contact.aspx to get the patch image?
Thanks
Raghu
JohnRo
Jan 09, 2017NETGEAR Employee Retired
Hi zappullae,
Sorry to hear that, I'll look up up your case and PM you the case number.
Thanks,
DavidTunstall
Jan 15, 2017Aspirant
Hi zappullae,
You may have the same issue I have been suffering from. Please read this article. It may help.
Regards
David
- zappullaeJan 16, 2017Aspirant
Hi David, that sounds like what is happening to me. I will try the solution as a last ditch effort.
And I have an S6. I can't say for sure but the problem may have started when I got the phone.
- zappullaeFeb 04, 2017Aspirant
Bad news. After about 3 weeks of problem free use the WAP just went south again! What a pain this is. I like Netgear products but this expensive one has soured me. I'm done using the WAP because it plain and simple just doesn't work.
- esaymFeb 06, 2017Aspirant
I totally understand. Disabling AMPDU is not the final solution I want or will accept. But it does get one up and running. I don't know what your symptoms were, but at least for me, I only had issues when mobile phones where connected to the AP. I had all mobile phones connect to the 2ghz radios in which I disabled AMPDU, and forced 20mhz channel width. Everything else was left at default. For 5ghz, I have all other non-mobile devices, laptops, desktops etc, connected to 5ghz where AMPDU is enabled. Everything else is default except I forced 20hmz channel width for 5ghz as well (I find that 40mhz channels enabled puts random lag sometimes).
But yes, I bought the 660 because I only needed something faster than 802.11g and wanted something that had been out for a few years and thus would be stable and bug free. Sadly not what I got since complaints against these APs for the same issues go back for 3 years and they are still unfixed. Sadly there isn't really any other APs that are purely standalone. There is the Ubiquiti stuff but they all require a separate controller to be configured or you have to install an app on your phone which is not what I want. - zappullaeFeb 06, 2017Aspirant
I totally agree. I have yet to notice anything that is causing the failure such as a phone or other device. All my machines and video devices are wired up for speed so its basicly its web traffic causing the problem.
- RaghuHRMar 03, 2017NETGEAR Expert
Dear All
Thanks
Raghu
- RaghuHRMar 07, 2017NETGEAR Expert
Hi All
Would like to know the feedback on the patch image if you have installed it?
Thanks
Raghu
- zappullaeMar 08, 2017Aspirant
I installed it but it can take a month before I know if it works.
Here's another thread on this subject
https://community.netgear.com/t5/Business-Wireless/WNDAP660-Connectivity-Issues/td-p/1194274
- zappullaeMar 12, 2017Aspirant
So far it hasn't hung up but its unsuablly slow. The propgress bar on FireFox (Samsung tablet) get to the place where it used to hang and pauses. Then 75% of the way and pauses. An Amozon product page takes forever to open. Unusable.
Well now it looks like I spoke too soon. The WAP had been slowing down and now its hung up. I'm done with this POS.
- zappullaeMar 13, 2017Aspirant
And it just hung up again. The fix made it worse. I took it down. Terrible device.
- zappullaeMar 15, 2017Aspirant
I'm sorry too. I'm only going to try one more thing, a factor reset and reconfig. If it hangs again its going on eBay.
