snoopy78's avatar
snoopy78
AC810S Firmware fehler
Dear customer support & community,
since some days i've got the new Deutsche Telekom contract Magenta Eins +, which includes a LTE/5G unlimitted flatrate.
I've tested the card within my Huawei B528 Homespot and 5G pocket router test sample from D-Link DWR-2101. Here the card works fine with 4G/4G+ and 5G.
Now i wanted to use the card in my car with the AC810S.
The card is active and the AC810S seems to be online using 4G/4G+. As soon as i now connect a WiFi client the AC810S is rebooting.
If i insert my older Vodafone sim card, the AC810S works fine.
So the behavior is caused by the AC810S having issues with the new SIM.
Please fix this bug asap, since i can't use the AC810S at all!!
S/N of the AC 50W17ANE003A8
installed firmware NTG9X40C_11.14.08.16
firmware update i can't do, since the automatic search doesn't return a result and for a manual firmware update the files i can't find..
Thank you
BR
Marcus
  • DamianM's avatar
    DamianM
    NETGEAR Moderator
    Dear Customer,
    You have contacted the German-speaking NETGEAR Community.
    We are able to support you only in this particular language. If you decide to contact us in German, please rewrite your question and/or describe your issue/problem so everybody can understand and participate if they want.
    Kind Regards,
    DamianM
    NETGEAR Community
    • snoopy78's avatar
      snoopy78
      Hallo,
      ok, dann in deutsch,
      ich habe eine neue Magenta Eins PLUS SIM Karte, welche in einem Huawei B528, D-Link DWR-933 sowie D-Link 5G hotspot DWR-2101 korrekt mit 4G/4G+/5G funktioniert.
      Im AC810S geht die Karte auch online, aber sobald ich Traffic verursache rebootet der AC810S.
      Mit einer alten Vodafone oder Telekom (prepaid) SIM Karte funktioniert der AC810S korrekt.
      S/N AC 50W17ANE003A8
      installierte Firmware NTG9X40C_11.14.08.16
      Ein Firmwareupdate kann nicht durchgeführt werden, da ich keine Firmwareversionen herunterladen kann (finde auch keine) und das online update keine neuere anzeigt.
      bitte behebt den fehler im AC810S.
      Danke
      • DamianM's avatar
        DamianM
        NETGEAR Moderator
        Hallo snoopy78,
        Dein Gerät hat die volle Modellbezeichnung "Telstra Wi-Fi 4GX Advanced III(AirCard 810S)", was bedeutet, das es ein Telstra-Produkt ist. Solche Produkte haben eigene Firmware-Versionen und werden von Telstra unterstützt, nicht von NETGEAR.
        Ich kann Dir nur empfehlen, sich direkt an Telstra zu wenden.
        Freundliche Grüße,
        DamianM
        NETGEAR Team
