Mäger
Apr 14, 2025Aspirant
GS110TPv3 SSH-Deaktivate
Hi, i have the problem that i cant find a good answer to the question: How do i diabel SSH on the GS110TPv3 ? Am i the onlyone ?
schumaku
Apr 16, 2025Guru - Experienced User
Permitting you have a current firmware in place on your GS110TPv3:
http://www.downloads.netgear.com/files/GDC/GS108Tv3/GS108Tv3_GS110TPv3_GS110TPP_UM_EN.pdf SSH Management Access, p.109 ff.
- MägerApr 17, 2025Aspirant
Thanks for the Quick answer!
My Firmwareversion is 7.0.7.1.
The button "Protocols" is missing.
I gues that it will apear if i update the Firmware ?
- schumakuApr 30, 2025Guru - Experienced User
This version 7.0.7.1 looks current according to the Netgear Support pages.
Wojciech_K bitte intern bei Netgear klären, danke!
- Wojciech_KMay 12, 2025NETGEAR Moderator
Mäger
1.1. Rufe das GUI des GS110TPv3 in einem anderen Browser auf.
1.2. Erstelle einen Screenshot vom Pfad «System > Protocols» und füge ihn hier hinzu.Mit freundlichen Grüßen
WojciechK
NETGEAR Team
Machen Sie mit!
ProSupport for Business
