leon2006
Jun 03, 2024Follower
NETGEAR Switch GS105
On the NETGEAR switch I am using, the LED lights up at a certain distance, what does this flashing mean?
The LED lights up for 1 second and then does not light up again for 1 second, it is not the usual flashing.
The Ethernet signal is only partially present, but when I pass the switch with a direct connection, the signal is permanently present.
My connection works as follows: PC --> Switch --> Switch --> device.
Can you help me further?
No RepliesBe the first to reply
Machen Sie mit!
ProSupport for Business
