IngMiad
Oct 06, 2023Aspirant
No connection of S3300-28X Smart Switch with Juniper Router using fiber optics
Hello, we have a S3300-28X ProSAFE 24-Port Gigabit Stackable Smart Switch from Netgear that we want to connect to another network via a Juniper router using a multimode fiber optics connection. ...
- Oct 30, 2023
Hello Netgear-Team,
we found a workaround to our issue by using another switch in between the Netgear and the Juniper-Switch. This switch can create a connection to both switches without issue and therefore is now being used as kind of "proxy" between the other switches.
Thank you for your help,
Greetings!
schumaku
Oct 08, 2023Guru - Experienced User
Double check the port is -not- configured as stack port 8-) - this setting is unrelated to the fiber link.
These older stackable switches might be picky on the SFP module, too.
Intentionally posted on the German language community section?
IngMiad
Oct 09, 2023Aspirant
Hello,
"Double check the port is -not- configured as stack port 8-) - this setting is unrelated to the fiber link."
>> We double checked the stacking settings. They are all set to "Ethernet".
"These older stackable switches might be picky on the SFP module, too."
>> We tested two different SFP modules. Both work fine with other fiber optics connections at our side together with the netgear switch. Only the fiber optics connection to the juniper router doesn't work with the netgear switch.
The juniper router also works together with other fiber options connection & switches at our side, just not with that netgear switch.
Machen Sie mit!
ProSupport for Business
