IngMiad
Oct 06, 2023Aspirant
No connection of S3300-28X Smart Switch with Juniper Router using fiber optics
Hello, we have a S3300-28X ProSAFE 24-Port Gigabit Stackable Smart Switch from Netgear that we want to connect to another network via a Juniper router using a multimode fiber optics connection. ...
- Oct 30, 2023
Hello Netgear-Team,
we found a workaround to our issue by using another switch in between the Netgear and the Juniper-Switch. This switch can create a connection to both switches without issue and therefore is now being used as kind of "proxy" between the other switches.
Thank you for your help,
Greetings!
Wojciech_K
Oct 25, 2023NETGEAR Moderator
Hi IngMiad,
welcome to the NETGEAR community.
I would like to get more data about the issue.
1.1. Do you wish to communicate in German?
1.2. What is the model name of the Juniper router?
1.3. What is the model name of the SFP module used?
1.4.1. What is the Configured Stack Mode of the stacking ports?
1.4.2. What is the Running Stack Mode of the stacking ports?
System > Stacking > Advanced > Stack-port Configuration
1.5.1. Please log in to the GUI of the S3300-28X and go to: Maintenance > Export > HTTP File Export > Tech Support > Apply.
1.5.2. Export the Tech Support file and save it as a ZIP file, then attach it to this thread.
Best regards
WojciechKrz
NETGEAR Team
IngMiad
Oct 30, 2023Aspirant
Hello Netgear-Team,
Greetings!
- Wojciech_KNov 01, 2023NETGEAR Moderator
- IngMiadNov 02, 2023Aspirant
- Wojciech_KNov 06, 2023NETGEAR Moderator
As the issue is resolved, I close the thread now.
Best regards
WojciechKrz
NETGEAR Team
Machen Sie mit!
ProSupport for Business
