GaoX
Nov 08, 2018Guide
BR500 - Das dreibeinige Lamm im Wolfspelz
Die Versprechungen waren hoch die Realität ernüchternd. Der Router kann maximal 4 Netze (Main und 3 Subnets) mit DHCP verwalten und einen Gateway zu Verfügung stellen. VLAN1 (Management VLAN) ...
c3po
Nov 12, 2018NETGEAR Expert
Currently local GUI can define up to 256 VLANs, out of these 256 VLANs, user can define 4 sunbets that BR500 is acting as DHCP servers.
Currently Insight APP does not sync local GUI VLAN settings, please make sure that settings from GUI and APP are not conflicting.
GaoX
Nov 12, 2018Guide
there was not a single line in the product description it could only handle 4 subnets with dhcp.
that no even enough to use 50% of the promised functions the router comes with.
the router schould be able to handle the insight network as its router part..
ps: sry for my whorse english i try my best
Machen Sie mit!
ProSupport for Business
