ChristineT's avatar
ChristineT
NETGEAR Employee Retired
Nov 13, 2024
CAX30 V2.2.4.2 Firmware Update now available for testing
Hello CAX30 Beta Testers,
Firmware Download:
https://ntgr.my.salesforce.com/sfc/p/300000000xsV/a/QU000001Qkuf/xmHYnrcHGeBXmOKhp7zc_MkOrI3XKGaKXut4vYf_XLE
Release Notes:
  1. Security improvements
Please start a new discussion when sharing your feedback. If you experience more than one issue, please create a separate discussion so that each issue can be documented and prioritized.
Cheers,
Christine
  • FURRYe38's avatar
    Ok, v2.2.4.2 loaded and installed, factory reset and setup from scratch.
    Found a couple of odd issues during the setup routing, 1. Using MS EDGE browser, After the factory reset when in with a wired PC win 10 and disabled all but 4 logging options and after hitting the apply button, the web page didn't refresh at all and thought I didn't select the APPLY button or incorrectly selected it, selected the APPLY button a couple of time didn't refresh the page so I selected a different menu item and the middle circle animation appeared and that was it. Did not clear after that and selecting any other WEB UI menu item failed to be processed by the browser. Seemed like the WEB UI Server hung up and stopped responded so I had to power off the CAX30 then back ON to regain access. 2. After changing the router IP address 192.168.0.1 and setting a new DCHP IP address range, .100 to .150 and then selecting the APPLY button, seem to take near 30 seconds for the modem and browser to update to begin the reboot process. Not sure if this maybe a performance issue or something different. May cause users to complain about wait time or not need the browser refresh giving indication of the change taking effect. Other than those two items so far.
    Just got it online with ISP.
    In Gateway mode.
    Will monitor and observe over next few days.
    • FURRYe38's avatar
      One issue I'm now seeing, seems like when I added a EAX80 with most current version of FW,
      It's not being seen on the NH app v2.41.0.34 or being tiled as Network Map to select for the EAX80 from the CAX30s main home page.
      I can access it using it's static IP address (192.168.0.80) I set on the EAX80 that is out side of the CAX30s default IP address pool range which I changes to smaller size.
      EAX80 shows it's connected and LEDs in front are all WHITE.
      I don't see the EAX80 listed on the NG app and I believe it's not appearing on the CAX30 web ui, I need to confirm this again.
      Can this be a Orbi app issue or a CAX30 FW issue?
      Prior testing was with the EAX80 and CAX80 RS600 and it worked there.
      • FURRYe38's avatar
        So after I got home, I checked the NH app and CAX30 ui and saw that the EAX80 was being displayed in both areas. I was at work earlier so I was remote. Not sure if Anywhere Access and remote impacts how the EAX80 is being seen or displayed. Otherwise, it is working at home.
