brianjmurrell
Feb 02, 2023Tutor
Can't reach GUI on GS308E over VLAN trunk port
I have a simple network with two VLANs, 1 and 15. VLAN 1 is the general LAN. Most ports on my switches are in VLAN 1, untagged as that's the VLAN most devices talk to each other on. So I config...
brianjmurrell
Feb 02, 2023Tutor
Ugh! Really!?!?
So deploy one of these switches anywhere in an existing network a never again reach it without walking over to it with laptop?
Well, I suspect it won't even get an IP from a DHCP server over a tagged trunk also, right? So definitely no reaching it.
Is this common? Do other brands (tp-link, etc.) of similar switches have the same limitation?
schumaku
Feb 02, 2023Guru - Experienced User
Correct.
All the product lines built around the same chipset series, implemented and offered by various brands, are affected.
Switch designs build on real fully blown managed cores. Keep your eyes open.
