Mooglestiltzkin
May 28, 2023Tutor
DHCP not working?
I use a Netgear Smart switch, but i use the local managed mode. I have a weird issue, when i factory reset, it uses DHCP by default which is fine. But oddly dhcp doesn't work when using my pf...
- Retired_MemberMay 29, 2023
It is a pfSense issue, not NETGEAR. Your ASUS router is VLAN-unaware so it works well with your NETGEAR switch in its factory default settings. However, you’ve created VLANs on your pfSense router. The pfSense port you were using needs to be added to the VLAN as an untagged member.
Mooglestiltzkin
May 29, 2023Tutor
my pfsense dhcp is setup like this for lan
192.168.0.0/24
192.168.0.25 to 192.168.0.90
Retired_Member
May 29, 2023
