jddaniels
Sep 19, 2021Aspirant
Gc510pp not connecting in insight
I just recently purchased a gc510pp and when setting it up it is not pulling any IP address. If I plug it into my xr500 and then plug my computer into the switch I can connect to internet but when I g...
schumaku
Sep 20, 2021Guru - Experienced User
jddaniels wrote:
I just recently purchased a gc510pp and when setting it up it is not pulling any IP address. If I plug it into my xr500 and then plug my computer into the switch I can connect to internet but when I go to insight it is still stuck on waiting for first connect. I have tried a different cable, resetting the switch, and tried finding the default IP address.
Is this a factor-new unit, or a pre-used device?
Something worth trying is to put a computer with an adapter into the 192.168.0.x/24 subnet, something like 192.168.0.123 255.255.255.0, and try to reach the switch on its default IP 192.168.0.239
Edit: Another point:Does the XR500 has some security configured, like issuing DHCP IP configs or Internet access to trusted/allowed MAC addresses only?
jddaniels wrote:
The switch does not show up when using the switch discovery tool either
AFAIK the GC Insight Managed Switches are not discoverable by the NSDT, indeed.
jddaniels
Sep 20, 2021Aspirant
So I am able to access it that way and I found it on my network but it is pulling just a private ip address and not connecting to the cloud
- jddanielsSep 20, 2021Aspirant
I do notice that when i log into the switch it shows cloud agent disabled.
- schumakuSep 21, 2021Guru - Experienced UserChange the mode on the switch from local to cloud management.
Rationale: Initially the first Insight Cloud Managed switches (GC models) as well as the later added cloud manageable models (by a simple firmware update or updated model versions adding more resources) always attempted to connect to the Insight Cloud. After complaints on a "calling home" mechanism - in fact implemented for an easy start only this default was changed to local and a local management action is required for Insight discovery over the cloud.
