akio63
Aug 04, 2022Aspirant
GC752X Switch Login Failure
I have a curious issue with the GC752X switch. After running for a while, the switch seems to lock up and will not allow any further logins. We have all the switches on a separate Management VLAN. ...
- Aug 04, 2022
Hi akio63,
Were there any events that occurred that may have caused this issue the first time you noticed it?
Would it be possible to update the FW of the switch to v1.0.5.35? Have you also tried a different browser when logging in and if the issue still persists?
JeraldM
NETGEAR Community Team
JeraldM
Aug 04, 2022NETGEAR Employee Retired
Hi akio63,
JeraldM
akio63
When this has happened in the past there were no network events prior to it's occurrence that I know of. Yes I can upgrade the firmware. I need to wait for a maintenance window but I was planning to do that anyway.
We are a government shop so we are limited in what we can use for software. Normally I would have tried a different browser but due to the restrictions I couldn't. I was already reprimanded, verbally, for using Chrome and it was quickly removed when it was discovered.
I'll let you know what happens when I upgrade the firmware.
Thank you.
- akio63Aug 08, 2022Aspirant
I have upgraded the switch to v1.0.5.35 and we have not had any issues with the switch for 4 days now. The Integration Team has been running scenarios all weekend long so the switch has been behaving perfectly. I will let you know if I still have issues but I believe this has been corrected.
Thank you.
