adlep2002's avatar
adlep2002
Initiate
Apr 16, 2020
GS108Tv3 simple VLAN setup problems
Hello, I am trying to setup a VLAN in my SOHO environment. I am trying to divide network in one part of my environment into two parts: 1. The original good ole 192.168.1.x class C 255.255.255.0 wit...
  • adlep2002's avatar
    adlep2002
    Apr 24, 2020
    Hello,
    This is a quick update about this project. Ultimately I have figured out that the L3 capabilities of this product are subpair and added just for decoration with a buggy interface.
    I have purchased Cisco SG350 10P switch and was able to make it work and it works very well. All objectives were accomplised with a bonus DHCP server configured on the SG350 and operating on the VLAN 172.
    SonicWall cooperated very nicely with the SG350 with routing rules configured in 10 minutes.
    One comment:
    1. When testing your setup in the lab in a non production environment make sure your SOHO router is able to setup static routes and do NAT for additional networks. That was a problem for me as I did not have an access to anything close in capabilities to SonicWall.
    2. When testing inter VLAN communication between hosts DISABLE windows firewalls on your Windows 10 clients (doh)...
    Thank you very much for your response and trying to help me.
ProSupport for Business
