Boomerang3
Mar 07, 2020Apprentice
GS308T vs GS108Tv3 Insight Management Support?
Just want to verify before purchase. 1. Both the GS308T and GS108T support management by Insight? 2. Specifcally, the GS308T which is cheaper, but doesn't support POE power will suport mana...
- Mar 08, 2020
Hello Jeff,
Current overview on all Insight manageable switch models -> Insight Managed Smart Cloud Switches - enabling more is in the works with Netgear, but there are no plans or schedules published. In my opinion missing are currently some 10G models - anything else is well covered.
Boomerang3 wrote:1. Both the GS308T and GS108T support management by Insight?
No, the S350 model line (with the GS308T) don't.
Boomerang3 wrote:2. Specifcally, the GS308T which is cheaper, but doesn't support POE power will suport management by Insight and of course SNMP capability?
The plain simple eight port with conventional power supply, Insight, and SNMP support would be the GC108T
-Kurt.
schumaku
Mar 08, 2020Guru - Experienced User
Hello Jeff,
-Kurt.
- Boomerang3Mar 08, 2020Apprentice
