bradleyv
May 02, 2018NETGEAR Expert
Insight Smart Cloud Switches 8/10-port models now support static routing!
Did you know? With the newest firmware release 1.0.4.6, all 8-port/10-port models of the Insight Smart Cloud switches now support static routing, just like the larger port-count rackmount models! IPv...
schumaku
May 03, 2018Guru - Experienced User
Nice, thank you Bradley! Is this feature coming soon to the GC728X/XP?
- LaurentMaMay 03, 2018NETGEAR Expert
Hi schumaku
Static routing feature has always been available on the 28-port models via the local web GUI; and it will be coming soon in Insight as well.
- schumakuMay 04, 2018Guru - Experienced User
Granted - we're using the Insight Switches with Insight management (only), figure....
- bradleyvMay 16, 2018NETGEAR ExpertFrom post: Currently, static routing needs to be setup using the local-only web GUI, but will soon be available in the Insight mobile app and Insight Cloud portal, so stay tuned for that!
