nuggets007's avatar
nuggets007
Follower
Oct 02, 2026
Insight: "Unable to apply the port configuration … Parsing error (status)"
Hi all,
Since recently I can no longer change port settings (port name / VLAN ID) on my Insight-managed switches through Insight. Every attempt ends with an email like this:
The following operation did not execute completely: Details: Device Name: <device name> Network Name: zuhause Model: GS724TPv2 Failure Reason: Unable to apply the port configuration for device <device name> as Parsing error (status)
Affected devices (3 switches, 2 models):
  • 2 × GS724TPv2, firmware (latest available)
  • 1 × GS110TPv3, firmware (latest available)
All three are online in Insight and otherwise work normally. The error only appears when I try to apply port configuration changes via Insight. I tried Insight Cloud Portal  and changed port name and VLAN ID, one at a time and several at once.
What I have checked:
  • Firmware is up to date on all devices.
  • The error occurs on different hardware models, so a single device issue seems unlikely.
  • The error appears to have started with the recent Insight update.
My assumption: Insight cannot parse the status response from the devices when applying port configuration. This looks like a problem on the Insight side rather than in my configuration, but I could not find any KB article or release note describing this specific error message.
Questions:
  1. Is anyone else seeing "Parsing error (status)" after the latest Insight update?
  2. Is this a known issue, and is a fix planned?
  3. Is there a workaround other than configuring the ports locally on each switch?
I'm happy to provide logs or further details if needed. Thanks!
1 Reply
  • schumaku's avatar
    schumaku
    Active Insight Subscriptions always include support.
    Head to https://my.netgear.com/support/contact.aspx (login inc case you are not...)
    Get Support -> Open a Support Case
    Select (x) I have a Subscription Service
    Select the Service Opitons:  Insight
    Best way is then to Call Support (Chat is often overloaded).
    Provide a -brief- description...
    (no idea why the online imsgaes are once more not showing up here again...)
ProSupport for Business
