ccl13
Dec 04, 2021Tutor
MS510TXUP compatibility issue with Mikrotik RB5009UG+S+IN via SFP?
I think that my MS510TXUP is not compatible with MikroTik RB5009UG+S+IN when connected via SFP port. The issue is this: When I connect my RB5009UG+S+IN via any SFP connection cable I have to MS510T...
schumaku
Dec 05, 2021Guru - Experienced User
Reads to me like STP is blocking the port virtually as the connection does come up.
<182>1 2021-12-04T17:53:10.144-8:00Z 192.168.14.209-1 STP-6-PORT_STATE proto_stp.c(835) %% Port XGigabitEthernet10 moving from Forwarding to Blocking
....some kind of loop in the network, the Spannng Tree Protocol - on either one or both sides - is blocking/shutting the port in the test set-up I'd suspect.
