Mooglestiltzkin
Mar 09, 2023Tutor
netgear insight cloud switch
I'm trying to be able to get insight cloud to connect to my devices over the internet. All i found was this https://kb.netgear.com/000062467/Which-domains-and-ports-should-I-open-on-my-firewall-for...
- Mar 10, 2023
Mooglestiltzkin wrote:
Then in insight i click the device, and it shows communication error.
I can only assume this means that insight is unable to reach my managed switch over the internet.
The insight cloud does never establish a connection over port forwarding.
Possible reason the Insight Cloud control can't talk to the switch is because the switch failed to establish a connection -to- the Internet and the cloud. To much things blocked on your firewall outgoing?
All this works very similar to MyQNAPcloud you are used to.
The local admin password pushed from the cloud is for the local device login from your LAN, rarely required.
Welcome to Netgear Insight by the way my friend Mooglestiltzkin
abacqdghfth
Mar 09, 2023Guide
Insight devices use https (TLS) to work with cloud.
are you able to ping insight.netgear.com from the VLAN where the devices are.
another common issue with devices unable to come online :
NTP is blocked. for https to work, the device should have correct time.
you can check if the time is correct from the local UI.
Incase switch got connected to insight even once, remember the local UI will get the password set from Insight.
(same as networl/location password)
- MooglestiltzkinMar 09, 2023Tutor
i pinged using windows 11 cmd from desktop pc
Ping statistics for .....
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 11ms, Maximum = 13ms, Average = 12msso i think it can ping, at least when i do so from my side.
my pfsense router has port stealth and don't respond to pings from the outside to my network firewall. could that possibly be why?
i am able to login to android insight to detect the managed switch on the lan to add it to my netgear network location (within insight).
After that point it says waiting for first time cloud sign in.
This is why i thought it was a portforwarding issue. So i tried doing so for pfsense to add port forward rule for nat to allow 443 https. rebooted router, then tested but didn't work.
so now i can only suspect it's because it's because pfsense is setup not to respond to pings from the outside? that's all i can think of right now.
- schumakuMar 10, 2023Guru - Experienced User
as for time,
the switch uses SNTP and is configured correctly to my timezone. in the UI it says Success for time update to the netgear time server. So i assume that is correct?
Yeah, when i added the device to insight, it gave me a password it asked me to use for login.
But i am not sure where they wanted me to use that password.
I tried the web ui, but that uses my own password i had already set. so not sure what is about.
