Mooglestiltzkin
Mar 09, 2023Tutor
netgear insight cloud switch
I'm trying to be able to get insight cloud to connect to my devices over the internet. All i found was this https://kb.netgear.com/000062467/Which-domains-and-ports-should-I-open-on-my-firewall-for...
- Mar 10, 2023
Mooglestiltzkin wrote:
Then in insight i click the device, and it shows communication error.
I can only assume this means that insight is unable to reach my managed switch over the internet.
The insight cloud does never establish a connection over port forwarding.
Possible reason the Insight Cloud control can't talk to the switch is because the switch failed to establish a connection -to- the Internet and the cloud. To much things blocked on your firewall outgoing?
All this works very similar to MyQNAPcloud you are used to.
The local admin password pushed from the cloud is for the local device login from your LAN, rarely required.
Welcome to Netgear Insight by the way my friend Mooglestiltzkin
Mooglestiltzkin
Mar 09, 2023Tutor
i am able to login to android insight to detect the managed switch on the lan to add it to my netgear network location (within insight).
After that point it says waiting for first time cloud sign in.
This is why i thought it was a portforwarding issue. So i tried doing so for pfsense to add port forward rule for nat to allow 443 https. rebooted router, then tested but didn't work.
so now i can only suspect it's because it's because pfsense is setup not to respond to pings from the outside? that's all i can think of right now.
schumaku
Mar 10, 2023Guru - Experienced User
