akio63's avatar
akio63
GC752X Switch Login Failure
I have a curious issue with the GC752X switch.  After running for a while, the switch seems to lock up and will not allow any further logins.  We have all the switches on a separate Management VLAN. ...
  • JeraldM's avatar
    Aug 04, 2022
    Hi akio63,
    Were there any events that occurred that may have caused this issue the first time you noticed it?
    Would it be possible to update the FW of the switch to v1.0.5.35? Have you also tried a different browser when logging in and if the issue still persists?
    JeraldM
    NETGEAR Community Team
ProSupport for Business
