Debtless4941
Jul 23, 2023Aspirant
running-config couldn't download but upload through HTTP is completed successfully.
Hi, I want to upgrade the firmware for the GS752TP version from 6.0.1.18 to 6.0.1.30. Before applying any change, I want to take a running-config backup. If I go to Maintenance > Upload > HTTP File...
- Jul 24, 2023
Same problem following a restart? Maintenance -> Reset -> Device Reboot, click the box and [Apply]
schumaku
Jul 24, 2023Guru - Experienced User
Debtless4941
Jul 25, 2023Aspirant
Hi schumaku Thanks for your advice. I won't be able to try the reset/reboot option as this is the client environment. I found how to transfer the config file via TFTP to a local drive, this time I will go for this option. Thanks for your help!
