pdjhh
Aug 20, 2023Tutor
Storm control rate actions
Hi there. I replaced some tplink switchesd with insight manageable 24 and 48 port switches (plus sfps). There are 5 vlans across this whole network but when I put the netgears across a particular...
pdjhh
Aug 22, 2023Tutor
I can’t see a port security setting in insight manager must be local only is it?
ErwinL
Aug 30, 2023NETGEAR Moderator
Hi pdjhh,
Apologies, looks like there is no port security via Insight and it's only available on local UI. Since you do not have port security set up and you have ports going up and down I suspect you might be experiencing broadcast storm. A packet capture might help find the culprit and looking at the logs. Do you have ring topology or similar to mesh type of network?
Have a lovely day,
Erwin
Netgear Team
