Jollyglow
Jan 14, 2024Follower
Unable to start RMA process
Dears,
I'm trying to request replacement of a GS108Tv2 switch under lifetime warranty. Its PD port for PoE power delivery appears to be broken. The switch does not accept PoE power and I need to use the wall plug.
Unfortunately, having tried several browsers throughout the last week, the hardware support request cannot be submitted. I receive the dreaded somethingWentWrong error after trying to submit my report.
Would anybody have any advice?
Cheers!
Give an alternate contact a try - https://my.netgear.com/support/contact.aspx#
The 802.3af (or 802.3at, 802.3bt, ...) PSE is able to power other PD using the same port and cable?
1 Reply
