Richard_li
Jan 03, 2020Apprentice
What does a Static DNS entry do on a managed switch
So I have read the manual, but if someon could explain in a non-network guys terminology it would help me out a great deal. As stated above I have a GC752X Inisght managed switch. Page 59 in the manu...
- Jan 05, 2020
Well, the only DNS query happening is for the "web.ddns.net" - from here you hit some NAT or port forwarding to a LAN IP and no more DNS query will happen on the LAN.
The only noteable exception might be if you run some load balancer or application proxy which can work internally on internal FQDNs.
schumaku
Jan 05, 2020Guru - Experienced User
Richard_li
Jan 05, 2020Apprentice
ok, so it seems I wont be able to get the NetGear switch to do what I'm looking for, but in case anyone else has something like this in mind, I just set the DNS on the switch to use my PiHole server, and adjusted the PiHole Server host file with the internal entries and all is well. tested that my external is still working as expected using the DDNS.net address.
Thanks schumaku for the help earlier, I be slowly learning netowrk crap!
- schumakuJan 07, 2020Guru - Experienced User
AFAIK the switch DNS server settings apply only to the switch management CPU operations.
- Richard_liJan 07, 2020Apprentice
I believe that is the case, since everything I have tried doesn't seem to get any sort of resolution to occur on the switch.
