MeddlingKids
Oct 06, 2023Aspirant
Adding Netgear PoE WAP to Orbi Network
I currently have an Orbi RBR850 router and two RBS850 satellites. I have Cat5e cabling running to several rooms in the house. If I have the Orbi satellites connecting to the Orbi router through a w...
CrimpOn
Oct 06, 2023Guru - Experienced User
It would help to specify the specific model of PoE Access Point.
No Orbi models provide PoE, so the device will have to be powered by a PoE injector.
Whatever it is, it should appear as a device on the network. It should be assigned an IP address by the Orbi router.
You should be able to connect to the device and "manage" it.
It will, however, not be part of the Orbi network. i.e. WiFi devices that connect to it will not roam seamlessly between this device and the rest of the Orbi network. if the devices are not mobile (do not "roam") then this will present no problem.
schumaku
As long as all devices - Orbi, WAX6xx, WAX2xx, Nightawk Mesh, or third party models - are configured to WPA2-PSK only, there is no Mesh platform or cloud support required to support seamless connectivity. A nice "feature" of this standard. This does not apply if intending to change everything to WPA3-SAE.
Granted, each "world" does have it's own management platform like Orbi or Netgear Insight, or the devices need to me managed individually.
- MeddlingKidsOct 06, 2023Aspirant
Thank you both for the reply. I'm trying to weigh making my current Orbi setup work, or just starting over and doing a rack setup with wireless access points throughout the house (UniFi).
