MiloDV
Oct 25, 2022Aspirant
BR200 add device problem 'An error occurred while processing the request. Try again'
Hi all My BR200 dropped its connection to Insight yesterday. After waiting for hours for it 'waiting for connection' then 'still waiting for connection' & trying rebooting etc. etc. etc. I finally...
Oct 25, 2022Guru - Experienced User
Is it a new purchase? You might be able to get it replaced/upgraded.
MiloDV
Oct 26, 2022Aspirant
Unfortunately no, it is a few years old & we don't have the original proof of purchase. We were also told by a Netgear representative that the SKR30 does not support trunking, which is key as we have over 4no. VLANs to set up. On that note I also understand that the BR200 does not support more than 4no. DHCP Servers. Not sure what to do about that one yet!
Many thanks for the suggestion though.
- schumakuOct 26, 2022Guru - Experienced User
Amazing, the same mis-infomration is still around with official support as well as community support.
Based on the similar designed BR500, BR200, SXR80, SXR50, SXR30 ... all can be configured to support up to 256 VLANs (deduct a few for special purposes), concluding the ability to configure a port to carry multiple tagged VLANs - this is what is typically named tagged trunk. This is available in the local Web UI as well as on Insight. Of course, this is for special usage or configurations only. Just on it's own with four ports, the possibilities are limited (except for putting up some trunks on the same or on different VLAN sets. Needless to say, you need to knw what you do - this is not a plug and play configuration.
The basic KISS default config does allow to have one VLAN per port, and support for four VLANs one on each of the four ports. But almost anything is possible.
While this might be correct, I don't know the relation to the inistial subject.
- MiloDVOct 26, 2022Aspirant
Many thanks for the suggestion. I've double checked & we had set up the DNSs as 8.8.8.8 & 1.1.1.1 a while back on both on the ISP device & on the BR200. There is also no smart filtering options that we can see. Everything has been working fine up until now.
What is also curious is that we have a GC728X, a GC510PP & 2no. WAX610. All of which run through the BR200 & are all still working fine, connected to Insight & everything. Rightly or wrongly, this suggests to me that the issue is not one of connectivity to the cloud. But one of initial setup which is stopping us from ‘adding’ the BR200 back onto the Insight. We have checked the obvious such as registration & subscription. We have also now taken all working devices back to factory default & started again. All of the above are still connected & are functioning on Insight, bar the BR200. Which is working via the web UI but we can’t get it back onto Insight. The only difference being is that we deleted the BR200 from Insight & not the others. As I said earlier, we have 2no. WAX610. So, I’m tempted to delete one of those from Insight & then try to 'add' it again. If that works without issues, then I am assuming it would point to a problem with the BR200 itself. As apposed to the Insight Cloud or a combination of the two.
With regard to the other comment you made. We had asked Netgear if the SKR30 supported VLANs & the answer was yes but not through 802.1Q. As we use trunking this made the SKR30 an undesirable option, so we went for the BR200. We have been using the BR200 with 4no. VLANs through one tagged port. But, it wasn’t up until now, while expanding the network, that we have found out that only 4no. DHCP Servers are supported. This is fine for our VLANs that have static devices as we are just going to use static IPs, but we require DHCP Servers on more than 4no. VLANs.
Anyway, that really is a side issue. The BR200 & Insight connectivity is the main issue. So, if you have any other suggestions that would be great.Many thanks.
It's nice to know the other insight devices are able to re-register successfully - this is just a panic reaction however - please avoid - creating a lot of work and activities. Always get in touch with Netgear support in these situations, or find assistance here on the community. The assigned community admins DaneA JohnC_V Marc_V or JeraldM can certainty help further. Can't speak for the BRx00 or the Orbi Wi-Fi 6 Pro systems - in general all these Insight devices have nice cloud logs which could help Netgear support to troubleshoot or provide hints.
Wild guess is that the EoL BR500/BR200 might be "lost" on Insight however.
blunt nonsense - wireless backhaul as well as the VLAN (yes) are of course dot1q based.
MiloDV wrote:
As we use trunking this made the SKR30 an undesirable option, ...
Netgear even offered that SKR30 as a replacement unit to late BRx00 customers which complained in time about ceasing the BRx00 EoL.
