Equest
Apr 12, 2020Tutor
BR500 Connectivity Issue - Port forwarding
I have configured port forwarding on my BR500 to allow access from the WAN to a port on the LAN for a webcam system, and this works fine. If I enter the FQDN:port on a browser anywhere on the intern...
schumaku
Apr 17, 2020Guru - Experienced User
The FQDN does most likely resolve to the WAN (Internet) public IP address as most consumer environment don't have a local DNS infrastructure allowing split horizon config. If port forwardings (or many2one NAT) can't reach ports from the LAN it's simply lack of, or broken NAT loopback. YeZ ideas?
PS: There are only two kinds of Internet direct accessible Webcams - those already exploited, and those which will be exploited soon.
- EquestApr 18, 2020Tutor
Yes, the FQDN is correctly resolved to the WAN address, however, the BR500 doesn't recognise its own WAN address when called from the LAN with a port added to the address, even though the port is recognised when the router is called from anywhere else on the internet. If I ping the WAN address from the LAN I get a reply.
I am using several webcams but these are accessed via a Synology NAS running video surveillance software - although I am not certain how secure this arrangement is. I note your comments about the security of webcams with a direct connection to the internet.
- Jan 04, 2019Retired_Member
