picacud
Jul 27, 2023Follower
Can't login to Orbilogin.com after using the Insight App
Recently, I tried to find a way to swap my 5G Wi-Fi to other channels through the Insight App. However, there are a few options on the Wi-Fi setting page( not even with the SSID Separation on the first wifi setting, which they have in orbilogin.com ).
Therefore, I try to log in on the site, and it requires my username and password, but they do not work at any of the sites http://orbilogin.com, http://orbilogin.net, http://192.168.1.1/, http://192.168.0.1
I factory reset it and finally can reset my username and password to log in to Orbilogin.com to swap my wifi options.
But then I open the Insight App again to see if my satellites are linked.
After this step, it seems like they changed the username and the password.
I can't log in to Orbilogin.com with my username and password after using the Insight App.
1 Reply
On the Insight App, click on [Location] then go to [Location Configuration] ... there you can set (and see) the local admin password you configured initially (!!!). The same fixed username admin is retained all over, as before.
Edit: The password fields you showed on your screenshots apply for the wireless SSID configuration only, and are never used for any kind of login. Avoid confusion by mixing up the local login with the Netgear Account login used on the Apps and here on the community.
