Aristomastrosi
Jan 25, 2020Guide
DHCP not routed on VLAN with insight cloud
Dear Community, I have a challenge I not get resolved. Hope you have some ideas how to fix it. The setup of concern is: 1. BR500 (Out on Port 2, VLAN 20 tagged, PVID 20, DHCP Server on V...
- Jan 26, 2020
Aristomastrosi wrote:...
2. GC108PP(In on Port 2, VLAN 20 tagged, PVID 20)
(Out on Port 6, VLAN 20 tagged, PVID 20)
3. Layer 2 Switch
There is the issue marked in bold text: As there is a plan L2 switch the VLAN 20 must not be tagged ... otherwise all ports (permitting the simple L2 switch does handle it correct) will run tagged VLAN, including the link to the client. Change the config for the link to the L2 switch on port 6 to VLAN 20 [U]ntaged PIVD 20.
schumaku
Jan 26, 2020Guru - Experienced User
3. Layer 2 Switch
