WisconsinBen
Nov 18, 2021Aspirant
Dual-WAN or LTE Backup Setup in Insight
I'm looking for either a dual-wan or LTE backup solution that'll work inside Netgear Insight. I see there are some things like the LBR20 but nothing in the webpage says it works with Insight. And ...
schumaku
Nov 19, 2021Guru - Experienced User
Hello Ben,
There is no Insight-capable Dual-WAN router yet.
If it's "just" about the ability to have a LTE backup, we're successfully using - here in Switzerland, so different models and variants available - LTE devices supplying broadband fail-over on transparent IP (required for the connectivity test) Gigabit Ethernet WAN links like the Netgear LB2120 (afaik not available in the US). Without much monitoring capabilities...
-Kurt
