GaACETech's avatar
Sep 29, 2016
Router - Dual WAN
A company I support has awful Internet access due to the cable company having issues.
There is another cable provider available.
The question:  which router can have two different WAN ports connected and will automatically fail-over if it senses a outage?  There are no VPNs.   The internet connection is to get to cloud based CRM systems that are business critical.
So - a router / switch with two different WAN ports plugged in and has auto-sensing capability.
Thanks.
Darryl
  • Danthem's avatar
    Danthem
    Sep 30, 2016
    I'd go for a FVS336Gv3 and buy a dedicated AP. You can use the FVS318N kind of like an AP by doing the following;
    *Factory default the FVS318N
    *Change management IP since the default IP of the FVS318N is the same as the FVS336Gv3
    *Turn off the FVS318N DHCP server
    *Create a wireless SSID
    *Plug the FVS318N in to the FVS336Gv3 using a LAN port (so LAN-LAN), do not plug anything in to the WAN port
    This is assuming that you don't use multiple VLANs in which case you may need some additional configuration. But like I said a dedicated AP is probably a good idea anyways.
    Attaching possible topology with the FVS318N:
  • fvs336gv3 should work, I only hvae one single provider here so cannot test specifically but the 336 supposed to do auto fallover between wan ports.
    • JohnRo's avatar
      JohnRo
      NETGEAR Employee Retired
      Hello GaACETech,
      dmacleo is correct, along with the auto-failover feature the FVS336Gv3 also comes with load balancing. Both WAN ports can be used as a primary or failover port. Please click here for complete details.
      Let us know if you have more questions.
      Thanks,
      • GaACETech's avatar
        GaACETech
        Guide
        Is there a WiFi version of the FVS336v3?   or just a Access Point?    we have a single WAN port Netgear now.   i think that can be made a AP.
ProSupport for Business
