MJ_Mnisi
Apr 08, 2021Follower
Enabling 2.4Ghz radio on a netgear Wac510 dual router
Hi all
I have a Netgear Wac510 dual band router in our offices,some android cellphones are unable to connect to the Wifi since well they use a frequency of 2.4Ghz, iPhone users are able to access the Wifi because they have 5Ghz frequency
What I came across when I logged in the dashboard as admin is that the 2.4Ghz radio signal is down and the 5Ghz is up
I have tried to reboot the device and updated the firmware but the 2.4Ghz signal is still down
Please help anyone
My email address is mj@cimmsa.co.za
Thank you
- natriotAspirant
DETAILS REVIEWS
Remote Mini Super Bass Speaker - BlueSupport: Bluetooth, TF card, USB, FM Radio, Line inSupport telephone redialBluetooth controller 20-15MIt can uphold music designs: , WMA,WAV, PE,FLACHigh affectability FM radio with inside antenna.Material: ABS Plastic + AluminumBuilt-in Li battery-powered battery 350mAH8) Battery can uphold play time: 2hours;Speaker size: 62*53 MM Support without hand when answer calling (with MIC)Auto Voice Prompt force on/off and Bluetooth
- PhelimFlynnAspirant
Using the iPhone radio is easy, and there are plenty of apps to meet your needs.
