Bob_Bamburg
Apr 23, 2019Guide
Error Communicating with Device
I was setting up the switch, creating a vlan on port 3, and lost contact with the device.
Could not access it via Web or Cloud interface.
After reading some posts in this forum, I removed the ...
MrJoshW
Apr 23, 2019NETGEAR Employee Retired
Bob,
Any configuration still saved to Insight will be pushed to the device once the device comes back up. If you can, in Insight, create a new location and only add the switch to the location and verify if the switch is able to come up and not disconnect from Insight.
If this works, verify in your original location if there are any changes made to the vlan that is causing a communication conflict with the switch when it is being added.
