adcliff
Apr 04, 2025Aspirant
GSM4212P (M4250)
Trying to add a GSM4212P (M4250) to the Insight portal but receiving the following "The device model is currently not supported by Insight". There are other devices of the same model previously adde...
schumaku
Apr 06, 2025Guru - Experienced User
Perfectly correct: It's not supported by Netgear Insight.
adcliff wrote:
There are other devices of the same model previously added to the portal.
Insight (App or Web portal) could of course be used for the product registration for adding any Netgear product - only by adding the serial number - this does just register it to your Netgear account. As you see, there are plenty of Netgear devices listed on my account - most are not Insight manageable FWIW:
- adcliffApr 07, 2025Aspirant
Thanks. Just for clarification, those devices show as not accessible?
- schumakuApr 07, 2025Guru - Experienced User
In absence of a Netgear Insight implementation on these switches, yes, of course. The message after "adding" a device to Insight stating "The device model is currently not supported by Insight" would make much more sense here, causing less confusion. Not a very clever naming scheme showing a "Not accessible", however the Netgear Insight team did not wanted to listen to the old men here who predicted "problem" reports from the field.
