CC027's avatar
CC027
Tutor
Apr 02, 2025
M4250 Can't Access Main UI Login
Hello, I recently updated to 13.0.5.10 firmware and now I can't access the Main UI Login page. The AV UI Login page works fine, just not the Main UI Login page. Here is what I get when I try the address of the OOB management port or any port for that matter "https://10.0.1.249:49152/v1/base/cheetah_login.html" :
  • Found the solution. I have to enable ip http secure-server
  • Has anyone seen or sovled this previously? I still can't access the switch via the Main UI Login interface.
    • CC027's avatar
      CC027
      Tutor
      • pechm's avatar
        pechm
        Good day.  I'm having the same issue.  Can you please tell me how to enable ip http secure-server. Thanks
  • Hello pechm. What do you mean with "Open terminal in the AV UI page"? Your screenshot looks like a terminal window. I searched for a link in AV UI page without success. Please, could you explain better? Thank you.
    • pechm's avatar
      pechm
      Hello Optoprim. Yes, I was just showing the commands to use in terminal. Once you login to the AV UI page, select diagnostics in the left pane, and then select terminal. This will open another page in your web browser. You will need to login and then execute those lines.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
ProSupport for Business
