dinosoar1
Feb 02, 2024Aspirant
Insight app for Mac says my device is compromised....
Been using the Insight app on my iPhone for a while. Just installed Insight on my MacBook Pro and upon launch, the window in the attached image appears and I'm unable to use the app. I'm running a Ma...
Music-IT
I have tested the Insight App om my MacBook Pro M1 almost a year ago and for me it never worked.
I can only recommend to use a browser for Insight on a Mac as the GUI is more computer oriented instead of the small display's we have on our smart hones. And the portal is more stable/reliable than the App.
p.s If you try the iOS Netgear Mobile App on a Apple Silicon Mac you will also see nice issues like a rotated interface 😉 So just don't use the Netgear iOS App's on a Mac as ....
Rgds
Rob
