dinosoar1
Feb 02, 2024Aspirant
Insight app for Mac says my device is compromised....
Been using the Insight app on my iPhone for a while. Just installed Insight on my MacBook Pro and upon launch, the window in the attached image appears and I'm unable to use the app. I'm running a Ma...
dinosoar1
Thank you all for your responses. Checking the App Store, I now see the banner alerting that only iOS apps are displayed, when searching for "Netgear." I've deleted the app and can now rest content in the knowledge that my Mac is actually NOT compromised! 😁 Thanks again!
- BrianLFeb 02, 2024NETGEAR Moderator
Hi dinosoar1,
Thanks for sharing this as this may help other Apple users (I almost forgot that apps and the ones that you previously downloaded might appear) that you might be able to download apps that are only available for iOS. It's also a good thing and a sight of relief to know that there's nothing wrong with our MAC.
Kind regards,
