Supertoad
Nov 11, 2021Aspirant
Insight app log info shows seemingly random devices connecting and disconnecting
Hi all. We have two WAX610 access points managed with the insight app. The log shows seemingly random devices connecting, disconnecting, unable to obtain IP addresses, and failing to authenticate. Al...
Supertoad
Nov 15, 2021Aspirant
Thank you schumaku. That is helpful information. We will have to try to find out if any of the devices have that enabled. I agree that supressing messages is a bad idea. I believe the DHCP server is set to hand out IP addresses to any devices that can connect to the Wi-Fi.
I think in the log sample I provided, there are only two entries stating authentication failed.
Pezor
Nov 20, 2021Aspirant
In for answers. I'm dealing with the same exact issue. I own WAX610 as well and getting these disconnect / connect client notifications.
- schumakuNov 21, 2021Guru - Experienced User
Do you expect that wireless clients - especially on battery powered mobile devices - retain the wireless connection 24*7?
Start with disabling this Random MAC feature (crapple marketing names it Private MAC) on your own wireless clients for the connections to your very own network to avoid confusion - so you have at least a stable base of known devices (read MAC addresses) for tracing.
Be aware this is not a hide-as-much-as-possible consumer Wireless router, too.
Last but not least, based just on a metoo message we can't help any further.
