ngearftard
Jun 24, 2019Luminary
XR500 Seemingly Just Rebooted Itself
V2.3.2.40
Windows 10 64-bit Pro 1903
I finished typing a short reply to a post after logging into my (large) gaming clan's vBulletin forum, click to post it, and get a send-related error. Notice no Internet per Taskbar. Look at XR500 and it's rebooting. All seems well a minute later, but I've never noticed this happening before (had the router almost a year).
What is/are the possible reason(s)? Nothing in XR500 system log before reboot (normal behavior IIRC). Is it supposed to reboot itself periodically? Can a reboot be forced remotely without authorization? Will it reboot itself if my ISP resets the connection for any reason?
Thanks in advance for anyone able to take the time to respond.
- Okay that could be why, if you touch the underside of the router do you notice if it’s excessivey hot?
No the router can't be rebooted remotely usless you have enabled remote access and you can the access to it from a remote location.
What channels are you using? Auto? This may have trigger a reboot as maybe having too many wifi neighbors would cause the auto feature to try to find a more less noisy channel. Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
- Netduma-FraserNetDuma PartnerHow do you have the router connected to power? If it is connected to a power strip and there are lots of devices connected to it then it may not have got the power it needed and therefore rebooted it. Connect it direct to the wall if possible and see if that resolves it.
- ngearftardLuminary
Router is powered from 900W uninterruptible UPS. Total UPS load at the time was no more than 170W with about half of that via strip router is connected to.
Netgear CM600
1 neighbor 3/4 bars vs 4/4 per my phone
Auto on the 2.4 and 153 on the 5
P.S. I did not have remote management enabled on the XR500.
- Netduma-FraserNetDuma PartnerIs it on a surface where it could possibly overheating like on a carpet?
