cifellic
Jul 25, 2021Aspirant
Insight Cloud Portal - I am unable to disable SSID
. The portal shows the SSID as disabled, yet my devices see and can connect to the SSID. The portal also shows the devices on that SSID that I have disabled.
DaneA
Jul 27, 2021NETGEAR Employee Retired
Was this working before?
What device is being managed by NETGEAR Insight wherein you wanted the SSID to be disabled?
DaneA
NETGEAR Community Team
- cifellicAug 07, 2021Aspirant
Yes it was working before, I have 3 wac 510 units. It was working before the last firmware/insight update.
- DaneAAug 09, 2021NETGEAR Employee Retired
Since the SSID shows disabled on the Insight portal, kindly try to enable it then disable it. Then, observe if the same problem will occur.
DaneA
NETGEAR Community Team- cifellicAug 09, 2021AspirantTried that several times. Does not work same result.
