cifellic
Jul 25, 2021Aspirant
Insight Cloud Portal - I am unable to disable SSID
. The portal shows the SSID as disabled, yet my devices see and can connect to the SSID. The portal also shows the devices on that SSID that I have disabled.
cifellic
Aug 07, 2021Aspirant
Yes it was working before, I have 3 wac 510 units. It was working before the last firmware/insight update.
DaneA
Aug 09, 2021NETGEAR Employee Retired
Since the SSID shows disabled on the Insight portal, kindly try to enable it then disable it. Then, observe if the same problem will occur.
DaneA
NETGEAR Community Team
- cifellicAug 09, 2021AspirantTried that several times. Does not work same result.
