tks-it's avatar
tks-it
Insight is not reachable
Hi there,
I was wondering if anyone has problems with connecting to Insight Cloud Portal. I can log in but it always pops up with an error that Insight is not reachable at the moment... this is doing for at least two hours for now...
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    tks-it,
    We apologize for the inconvenience this has caused you.  😞
    This is currently being fixed.
    DaneA
    NETGEAR Community Team
    • tks-it's avatar
      tks-it
      Thank you very much. I just started to change SSIDs, rules and passwords ... and then kaboom 😄
      Thanks for the reply.
      • DaneA's avatar
        DaneA
        tks-it,
        Just an update.  The issue is now resolved.  If you encounter any problems, kindly try to log out then log back in.
        If in case the problem still occurs, I suggest you to open a support ticket with the NETGEAR Support Team here at anytime for further assistance.
        DaneA
ProSupport for Business
