CBS-jbcbussoft
Nov 13, 2018Guide
Insight VPN connection to BR500 questions
I am trying to setup a Client to Gateway connection. I have the BR500 configured to use DDNS. I have setup a VPN group, sent an invitation, installed software on my computer, and connected the Insigh...
- Nov 21, 2018
I just got an email asking me if I had a solution to my issue. I do but it did not come from the forum. I had already performed all of the steps required to create the tunnel before I posted my question per my original post. Not finding a solution here I contacted support and was able to get the tunnel up and running. I posted this info to this thread as well. How do I close this thread?
schumaku
Nov 13, 2018Guru - Experienced User
Agree. Can't find more than the very few vague lines above the OpenVPN info on the user manual. From what documentation you get the impression that this is workable (I agree, technically it has to work).
I'm just buffed that nothing of all that is in the official documentation or the KB.
CBS-jbcbussoft
Nov 13, 2018Guide
If we get this working I will post the how-to.
