KGA20
Oct 21, 2021Aspirant
Insight widgets Usage clients and usage traffic show incomplete graphics
Hi community, I want to report a bug that affects widgets titled "Usage:Clients" and "Usage:Traffic". Graphics are not complete. As you can see on the following screenshot, the graphics are cutted ...
schumaku
Oct 21, 2021Guru - Experienced User
Strange, looks fine here:
KGA20
Thanks schumaku for your reply.
My versions are:
Web Portal Version : 6.3.26.7
Cloud Version : 6.3.26.8
do you have the same?
- schumakuOct 21, 2021Guru - Experienced User
Difficult to have something different - it's a production system:
NETGEAR Insight Pro
Of course there can be certain flaws... YeZ any ieas what can go wrong there?
- KGA20Oct 21, 2021Aspirant
I do not know if can help: All my devices are WAC505 y WAC510 and i am using last Google Chrome Versión 94.0.4606.81 (Build oficial) (64 bits)
Works similar on all current Chrome, Chrome Beta, Firefox, Edge here.
Those graphs "hanging down" from the top line visible on your screenshot look suspicious, too.
- Sep 07, 2016Retired_Member
