TheGrumpyGent
Apr 21, 2022Tutor
Issue w Wireless Options with Insight Managed Orbi
In the Netgear Orbi Pro (SXR80), there is an option in wifi setup that supports "WPA2-Personal [AES] + WPA3-Personal". I had everything setup local, then tried to add the router to Insight managemen...
DaneA
Apr 21, 2022NETGEAR Employee Retired
What is the current firmware version of your SXR80?
Do you have an Insight Premium subscription or Insight Pro subscription?
Kindly post screenshots that shows "WPA2-Personal [AES] + WPA3-Personal" locally and Security page in Insight wherein it shows no option for "WPA2-Personal [AES] + WPA3-Personal."
DaneA
NETGEAR Community Team
- TheGrumpyGentApr 22, 2022Tutor
DaneA wrote:What is the current firmware version of your SXR80?
DaneA
Hi dane , thanks for the reply! I have the Insight Premium sub that comes with the SXR80, and I have the latest firmware (V4.2.0.122).
I've attached a screenshot of the security options from within the Insight portal, as well as the options visible within the local admin UI. You can see the "WPA2-Personal [AES] + WPA3-Personal" option isn't available from Insight.
Here is the Insight Portal options (only let me have one attachment at a time 🙂
Hi DaneA , please let me know what you find.
- jchen135Apr 22, 2022AspirantI have the exact same setup and issue
